will this cheap ol' build work.
http://pcpartpicker.com/p/uH5r
well?
Dude, just get the A10-5800K. Drop the optical drive or something. The A10 is only like $15 more.
Agreed, the a10-5800k will give you a significant performance boost and is an all around great chip for the money.
i would get both the a10 and optical drive.
the optical drive you might need it in some ridiculous situation so i would get both.
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1146365 .... This combo is a little bit more expensive but better (Mobo and A10 CPU)
The PSU could be improved. It has an 80 PLUS stamp, but not many reviews, all bad if any. I would suggest the Corsair Builder Series 430w, high quality product, and for a little more it can be semi-modular.
ok thanks
Tthe combo suggested by Cody3000 is a very good deal. Get the Corsair Builder 430W if you intend to only use integrated graphics. If you intend to add a good video card later, than get the Corsair Builder 500W.That hard drive is really small and youre not really saving that much money on it. You can find a 500gb for around $55 and a 1 TB for around $70 if you look for the sales.
Also, do you intend to overclock? If so youre going to need a better motherboard (http://www.overclock.net/t/946407/amd-motherboards-vrm-info-database).
Here's a couple suggestions:
http://pcpartpicker.com/part/asrock-motherboard-fm2a75pro4m
