Cheap Laptop For C++ IDE & Web Browsing
Hello, currently I am in need of a cheap laptop that can handle a c++ IDE.
Any advice is appreciated.
-If possible I am looking for an inexpensive option
-I am using the laptop for learning C++, not for big projects, so a lot processing power is unnecessary if it adds to cost.
Currently I am looking at installing Linux on a Chromebook.
Just get a windows 8 tablet with a bluetooth keyboard of your choice. a lot of the smaller laptops have pretty sub par keyboards, the Winbook has a full USB port as well.
Throw in a bluetooth mouse and you're golden
Thanks for the advice, I will look into it.
Plus you can hook up the tablet to any old battery bank, it should charge by micro USB anyways
