Cheap case to mount a h100i in push pull?
I need a cheap case that I can mount a 100i in push pull. My current case the corsair 200r will not do the job.
Get a Fractal Design R4 or Fractal Design Xl rev. 2. The R4 is a mid-tower, and the XL is a full tower. Fractal makes very good products, and the R4 is around $85. It is almost entirely steel, and has great options for cable management and cooling. The H100i performs well, but the NZXT Kraken or Kraken x60 would have been a better choice. The H100i still works great, but the Kraken performs better for the money, in my opinion.
just woundering but why wont it do the job? iv seen a 240ml rad be fitted in front of that case before now with a bit of modding admitedly, also are you trying to run push pull in the the roof and just dont have the clearence for the board and ram etc?
