Cheap case that has room for 240mm or 280mm radiator
I want a case that I can fit an all in one water cooler for my cpu. I am looking to replace my  corsair 200r because it has poor airfloor. This is the best case for the price. http://www.newegg.com/Product/Product.aspx?Item=N82E16811146080&Tpk=nzxt%20tempest%20410
 http://www.amazon.com/Nzxt-Technologies-Tempest-Elite-Airflow/dp/B005MMW4FA/ref=cm_cr_pr_product_top
What is your Idea of cheap? I'm guessing under $100? I personally love the NZXT Phantom 410. It has a little "Fan Controller" and looks more pricey then it really is.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146085
I had a H100i running with one of these cases and it fit perfectly
I have the rosewill Thor V2, I got it on newegg when it was on sale for about $100. It has great airflow and is massive, you can put just about whatever you want in it. I think it can hold a 240/280mm rad but I'm not sure, You should probably look it up.
I like the phantom 410 and seems to have alot of clearence for a 240mm radiator.
I have the Phantom 410 and it will fit something like H100/H100i just fine. But for the Kraken X60, by default it won't fit because of the space between both 140mm fans I think, but with a bit of drilling, it will fit.
http://www.nzxt.com/new/news_detail.php?id=318
Id get a Bitfenix Shinobi or a Fractal design Arc Midi, the Shinobi is sturdy compact and can still mount quite a few rads, and the Arc midi is a watercooler on a budget's dream.
