Earlier today i was gifted a Thermaltake Water 3.0 Riing 280mm AIO, i’ll take this opportunity to move my system into a more modern chassis and incorporate the AIO to the system.
I want a white chassis with at least one 5.25 bay, so i took a look at the CM Stryker SE and the Corsair Air 540.
I really like the Stryker SE but i’m concerned whether my AIO hoses will be able to reach the front of the case.
Do you guys think it’ll fit? If it doesn’t, i’ll just settle on the Corsair Air 540.
P.S.: I must mention, a few months ago i bought a (defective) CM Cosmos SE, which is slightly shorter than the Stryker and i was able to install a Corsair H80i v2 in a similar manner:
