So I bought a Chasar MK-I case, and I also go a NZXT Kraken X60.
The problem I'm having is that I have no idea where to put the Kraken. I was thinking on top, but it does not fit.
I don't know where to put this thing. Does anyone know how to put it in or have any ideas?
Get a drill man, It's case modding time.
Don't think that would work. See the top of the case and hold 2, 200mm, 140mm, 120mm fans.
I thought that would be fine. seeing hown the Kraken X60 has 2 140mm fans it should fit. I was wrong, there is a space between the 2 140mm fan. Now that I see it, it makes sense. There has to be that space to the 2 200mm fans would fit.
anyway pretty much what I'm saying is that there it no frame to drill into on the top.
I can screw half of the Kraken in but then the other half would not be in.
yeah your probably going to have to find a way to externally mount that or pull out hard drive cage becuase the chaser mk-1 is not the best of cases for watercooling but if you manage to pull that off i would love to see how that works for you good luck.
I put it on top of the case, under the 2 200mm fans. I only screwed half of it on. I can drill 2 holes and get a little more suport for it.
I was thinking. A buddy of mine works with sheet metal for a living. He could make me something that can reach the holes. Kinda like a brige so i can between the screw holes on the Kraken, and the mounting holes on the case.
good thinking bluesmurph, i had to do some modification to get my x60 to fit too.. drill, dikes and a lot of filing... it was worth the bs to me.
