Charger and power outlet question
Hey guys
I’m from Italy but I found a good deal on a dell laptop here in the US. Will I have any trouble with the charger or the power outlet ( except for the plug adapter of course)?
Doesn't most of europe have 220V or something like that? You just need an adapter most likely.
Yes we run on 220 volts, I was just wondering because my phone had some problem charging over here and I didn't know if it was due to the power outlet. Thank you anyway
No, you shouldn't. Laptop adapters have been dual voltage for a long time. Just make sure it says 120/240 on the adapter and you're good. Lots of electronics are dual voltage. Otherwise, you should use a voltage converter, as you originally asked.
