Installed Gnome Alsa Mixer, and then this libraries (libc6:i386 libglu1-mesa:i386 libxcursor1:i386 libasound2:i386 libasound2-plugins:i386 libqtgui4:i386). Now the sound is working. Probably due to the libraries. Just need to make my controller work and I'll be all set, to buy that game that made me start this.
Strong the Force is in this one
Not any more. Had some issue and the PC wouldnât start. I looked but didnât had any Linux installation device, so I installed windows 10. It was crashing like crazy, downloaded Linux mint and installed, some of my favourites, programs werenât compatible with it, so back to windows, now 8.1. It was still crashing to much, had a look at the PC and didnât found out anything wrong, remembered that Linux disabled the windows microcode, used a live cd to enable it and windows got better. Now using windows again. I missed using the shortcuts at my mice extra keys, and this is keeping me in windows, for now.
Talk to your kids about canonical, before someone else does.
Welp⌠How is your linux experience?
Linux is hard to make it work right. It requires a set of skills which I havenât mastered. The command line is a must know, not all of it but a lot. And when you âfixâ something you probably broken something else. It requires time and attention. I like it, but Iâll let it mature some more before having another try.
What exactly do you here? Lol Iâd doesnât disable microcode, itâs loaded by the OS. Microcode on windows is managed by windows and loaded when it boots. Linux does the same, itâs the same microcode.
Adding to this:
Once you get a microcode update, its not like you can roll it back either. Itâs permanent.
Platform agnostic.
This doesnât seem to be well understood. My understanding is microcode updates must be loaded every boot. If you remove the microcode package from your Linux OS you lose the microcode updates (unless your loading them via the bios)
http://metadata.ftp-master.debian.org/changelogs/non-free/i/intel-microcode/unstable_README.Debian
Oh yeah you can definitely revert or remove microcode. Just as you say @Eden it is rolled into the boot process (he read the procedure, set it up, and promptly forgot the details) and can be modified or removed as you like. As for Windows, I canât say since I have been away for so long.
