Changing the led color on my 1700
I am using an asus b350, and the stock cooler for the 1700. How do I change the color on it?
The cable that came with it plugs into a 4 pin LED header. If your board has one you are set & can change it like any other rgb thing. If it doesnt then probably make your own controller or something
I can't find any software.
  1. What B350 motherboard is it.
  2. It's going to be on the motherboard controls in the BIOS or in the motherboard control software (i think Asus's is called AI Suite)
