As said above should work fine. Things to do in preparation though,
Go into fstab and comment out automount of any drives that are not the boot drive, in case the controller can’t see them. If you don’t know what this means or you don’t have any secondary drives, ignore.
Create a full backup of any critical data. Ideally image the whole drive.
If you have any VMs, especially pcie passthrough, disable them before migrating.
