Ok,
I wanna build a computer using the new 660.
im broke
my challenge is for you to make me
THE CHEAPEST COMPUTER WITH A 660 (non ti)
I was thinking a fractual design 1000 case (i hate ugly cases)
Ok,
im broke
u do know that one problem u may run into is that if the cpu is cheaped out on then it could pose a potential bottleneck to the gpu, also y do u want a 660, are u running multiple monitors in surround, wat exactly r u looking to achieve.
also if u r broke then i would suggest going for an overall budget build.
got it, I'm super tired though so I'll make one along with this other dude in the morning
also a G850 will do as well in games as a 8150 or 955BE, and its pretty cheap the ivy counterpart is even better
^^ I was thinking that cpu too
NOT BAD, Thanks giga!!!
Also, If their was one thing you could upgrade on this build what would It be?
well you got a lot to choose from
the mobo to z77 for upgradability and functions
a stronger Cpu such as the 3220, but that would need a bios update with a sandy chip in, which you could do if you know any friends who have a sandy chip
also a rosewell green 530w is only liike 10 bucks more but it wasn't comboed and I was trying to stay under budget
