So after about a week of mining, CGMiner decides to stop working. Whenever I launch the bat file now, it flashes open for a split second saying "cgminer.exe is not recognized as an internal or external command, program, or bath file." then closes.
My settings
etx GPU_MAX_ALLOC_PERCENT 100
setx GPU_USE_SYNC_OBJECTS 1
cgminer.exe --scrypt -o http://mining.usa.hypernova.pw:3333 -u TheFatAsianHorse.1 -p x -I 18 -v 1 -w 256 -g 1 --gpu-powertune 20 --temp-cutoff 95 --temp-overheat 90 --temp-target 80 --gpu-vddc 1.090 --temp-hysteresis 3 --thread-concurrency 24000
Specs:
HIS HD7950
13.11 Beta drivers
CGMiner 3.7.2
