I just built a new pc with an old case. I was looking at the Cfi taiji a7007 case. I'm getting a new one before summer and i think that i want a full sized case. At microcenter it is $96 after tax. I was thinking is it to cheap or should i get something different.
Fractal Design Arc Midi R2
- http://www.amazon.com/Fractal-Design-Solid-Computer-FD-CA-ARC-R2-BL/dp/B00EWHMY4W/ref=sr_1_2?s=pc&ie=UTF8&qid=1395086802&sr=1-2&keywords=fractal+design+arc+midi+r2
- http://www.newegg.com/Product/Product.aspx?Item=N82E16811352031
- http://www.microcenter.com/product/414591/Arc_Midi_R2_Mid-Tower_ATX_Computer_Case
I think that might be my second choice, because i like the style of the 7007 better. Thanks.
In that case (no pun intended), if you are considering breaking the $100 mark, I would start looking at NZXT cases. They have that similar look.
Anyway, hope I helped a bit and I hope your purchase goes well !
Don't build PC while drunk !
Thanks again.
