So I have three CentOS 7.5 servers running Docker. They’re in a Docker Swarm together. All are masters/workers.
When I try to run any container with a specified named volume, I get this error:
SELinux relabeling of is not allowed
The “of is” implies to me it doesn’t know what it’s trying to relabel, but considering this only happens when I specify a named volume to mount, like so:
-v portainer_data:/data
I imagine the path that should be there is almost certainly whatever that named volume is. This works fine when I specify the path, like so:
-v /var/lib/docker/volumes/portainer_portainer_data/_data:/data
Which is where it’d be going anyway.
# docker volume inspect portainer_portainer_data
"Driver": "local",
"Labels": {
"com.docker.stack.namespace": "portainer"
"Mountpoint": "/var/lib/docker/volumes/portainer_portainer_data/_data",
"Name": "portainer_portainer_data",
"Options": {},
"Scope": "local"
But that isn’t the same named volume?
That’s how Stacks work in Docker Swarm. The volume name is prepended with the stack name. So I can have two stacks, portainer
and portainer_2
and it will create two separate volume portainer_portainer_data
and portainer_2_portainer_data
to prevent collisions between volume names in different stacks. So specifying -v portainer_data
for a stack called portainer
will resolve to portainer_portainer_data
as the volume.
I’ve tried doing this -v portainer_data:/data:z
and -v portainer_data:/data:Z
Same error. I’ve tried doing this:
chcon -Rt svirt_sandbox_file_t /var/lib/docker/volumes/
chcon -Rt svirt_sandbox_file_t /var/lib/docker/volumes/portainer_portainer_data
chcon -Rt svirt_sandbox_file_t /var/lib/docker/volumes/portainer_portainer_data/_data
I realize -R is recursive, but after doing each, I tried starting the service, and it still resulted in the error.
The reason I want to use a named volume is because Swarm syncs them (AFAICT based on documentation), and I don’t think it does this with a specified path? Not 100% on that tbh, the documentation wasn’t very explicit in saying so for either format.
How can I make this happen without disabling SElinux? Google is failing me in that I found an RHEL 7.5 page for it, but I’d have to be a subscriber and I’m not. And there are no other found instances of this error that specify a way to solve it.
