Caution: PowerColor's PCS+ Series is Faulty
I'm gonna give PowerColor a benefit of a doubt, and say they still make quality components. However, their PCS+ series isn't one of them. Their R9 290(x) PCS+ are notorious for performance degradation. I highly doubt this is just case of faulty bios, I think this problem goes deeper than that. This problem lies in their Q/A control, and their poor choice of components (made in China).
Anecdotes from other people in another forum:
"Hi Guys,
Just to let you know, I've received the updated BIOS for my 290X PCS+ from Raymond however it hasn't made any difference when it comes to performances. Basically my 290X PCS+ performs at the same level as my 290 PCS+ (verified by running 3DMark, Unigine Heaven, Unigine Valley).
Informed Raymond which reported to me that Powercolor is investigating the problem.
Cheers" -Schussnik
"290 pcs+
ran a few tests overclocked
12v drops 11.5v with load
1200-1650
3d11 gpu 16200
overclocking doesnt effect performance as it should. Scores same as old bios when oc'ed
i'm bored with these cards, super cooling yet doesnt perform as 290"-daymond
"Update:
Replaced motherboard
Clean install windows 7 64....13.2 drivers....system drivers...
FAIL
I am now pretty sure after 2 cards new Mobo+psu some cards are faulty. Both had hynix ram.
Do not buy this card unless you test before."-daymond
From Youtube:
"I just think the card that we had degraded for some reason very quickly"
www.youtube.com/watch?v=OD8hvKvdfdw&list=TLxg8ex2mWvNXaA_wuAegXnEXbtkct_IBo
I've ran benchmark test myself and can confirm this performance degradation. My Asus HD 7970 Direct CUII outperformed my PowerColor R9 290x PCS+ by a big fucking margin.
At Extreme HD Preset in Unigine Valley:
PowerColor R9 290x PCS+ (@ stock speeds of 1050 core/1350 memory)
  • FPS: 12.7
  • Score: 531
  • Min FPS: 6.8
  • Max FPS: 24.6
Asus HD 7970 Direct CUII (@ stock speeds of 925 core/1375 memory)
  • FPS: 37.5
  • Score: 1568
  • Min FPS: 20.2
  • Max FPS: 69.2
If you decide to buy a card from PowerColor I'd suggest going for the Devil 13 series, their flagship series of card. I willing to bet that's where all the quality components went to. As for myself, I'm back to playing on my HD 7970 again while I issue a RMA with PowerColor.
