Meybe some ideas. What cold be beter in this sistem?
Inportant! I have 5.1speakers.
Case : Fractal Design Node 304
Motherboard: AsRock B75M-ITX
CPU: Intel Core i5 3570
CPU cooler: THERMALTAKE WATER 2.0 PERFORMER
GPU: GeForce 9800GTX+ (my old GPU & Iove it)
RAM: Kingston HiperX DDR3 8GB 1600Mhz
PSU: Corsair CX600
SSD for OS: Kingstoin 120GB
Ext. HDD: WD 500 7200rpm sata3
Defenitly buy a better GPU. I can reccomand one as soon as you give us a budget.
INGSOC
June 8, 2013, 1:53pm
#4
If this is a budget computer build, then please, don't use the old GPU on the 1 PCIe port you have! Go to CeX and get a GPU or something for 5p but don't use an old card with a 3570
The 3570 with the 9800GT, is a bit of a mis-match. Allocate your funds appropriately, design a balanced system.
