A friend of mine is having me build him a pc. He doesn't game, edit, or anything intensive, but he does do some major (casual) multi-tasking. Browsers and multiple programs/files/documents open at once. This told me that he needs a decent amount of ram and an ssd, so we have that settles. He likes to use either multiple monitors or one high res monitor. We haven't decided on what would fit better (depends on what we find at a price he likes, etc), either one high res or multiple smaller ones. With that in mind, he wants a mini-itx build. I have everything worked out for the most part, however..... I am a little unsure on the cpu choice. Because he was talking about higher pixel counts, nothing cpu intensive, and multi tasking, I figured that an apu would be the best route. It has strong integrated graphics and is a true quad core (as far as I know, as opposed to the "modules" with two "cores" each which are common in the fx line). My gut instinct is that something like a locked i5 would be the best choice, but I am not too keen on Intel overall right now. From the tests that I have seen, something like an a8-7600 SHOULD be plenty for what he does, and should have enough graphics horsepower to do just about anything that he might want to do in the future with regards to multi monitors and maybe some light gaming, etc. IT should make for a good all-around system. I am just weary about going this route as he is a friend of mine, and I feel a bit like I am using him as a guinea pig seeing as how I have never messed with the apus before and don't have any real world experience (and it is hard to gauge their performance fore his needs as benchmarks on "general multi tasking" isn't something that is too common on review sites and would differ person to person anyway).
tl;dr Would an a8-7600 build be a solid build for a few years for general purpose use?
