Cases similar to Silverstone Fortress Series FT03-MINI - 90 Degree Orientation cases (cables and fan exhaust out the top)
Anybody else know of any other 90 Degree Orientation cases (cables and fan exhaust out the top)?
Found so far:
- Silverstone RAVEN RV01
- Silverstone Fortress Series FT03
- Silverstone Fortress Series FT03-MINI
- Silverstone Fortress Series FT05
I like the FT03-MINI the most because of the more direct single flow of air, the FT03 on the other hand seems to bounce air around the case.
Trying to target an Micro-ATX or larger sized case.
Cheers!
If I remember correctly, Silverstone has some sort of bullshit patent on 90 degree mobo... I could be wrong though, that's just what I heard somewhere.
In that case, they're the only manufacturer that makes cases like you described...
They don't. because Case-labs has them as well.
I forget which case this is.. but it's definitely a caselabs case.
BUT you have to customize it yourself. (Some of their cases allow you to change the motherboard orientation.) I'm a Silverstone FT03 owner. (Still currently use it) and honestly in the mATX sector. Silverstone is the only OEM that has a 90 degree orientation motherboard layout mATX case. you aren't going to find them anywhere unless you go silverstone.
Perfect! I don't know where I got that idea from. Seems a little big, but a great case nonetheless. Does Caselabs make any FT03 like cases?
No. Caselabs primarily makes full blown E-ATX cases that have the holy grail support for Water-cooling. Silverstone is the the only OEM to have a mATX case with a 90 degree motherboard layout orientation. no one has bothered to make an mATX case with the 90 degree orientation. and honestly the only reason i think it is, is because it would look too much like the FT03.. that case is so unique, i'm pretty sure anyone else would take backlash if they made a case like that.
