Morning everyone.
I'm looking for cases with I/O ports on the top and the motherboard mounted in said fashion.
Any ideas?
Morning everyone.
Any ideas?
There are several good ones I've seen but can't think of their names. Search on TigerDirect and/or NewEgg. I know Corsair has made one such case. Be sure to get one that has an easy access door in it or reaching your cables and USB ports is going to suck any time you need them.
Why do you want such a case btw?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163185
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163259
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163265
http://www.silverstonetek.com/product.php?pid=292
I believe silverstone owns the patent on 90 degree inverted cases so look at their selection and see what you like/can afford with a 2nd mortgage
There is also the cheap Bitfenix Outlaw.
Ok thanks for the links.
