Okay, so it's not exactly a war, but here is the build I am looking to purchase in the next couple of months. I will post the build below, but the three cases I am trying to choose between are the Coolermaster CM690II Advance (with the window), the Tt Chaser A41, and the BitFenix Ronin.
So far the arguments for and against are are: the CM690II advance seems a really solid, sturdy case, has the blue LED fan in the fron that I am looking for, tonnes of options, but a bit more on the pricey side especially when considering buying a couple more LED fans for it
the Chaser is a tad more expensive, but has more included LED fans which would remove the later costs of buying more LED fans
The Ronin is clearly cheaper, but I just really want to find out if it will be possible to see the colour if i stick an LED fan in the front. also would want LED fans later on.
Also, while I am at it, I was wondering if the community could just double check the compatibility of all my parts.
This is the build: http://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=150283&action=wish_lists
The cases: http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_1171&products_id=23686
http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_31&products_id=18723
http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_1081&products_id=22746
The stuff I plan to purchase later on, if/when more money becomes available: http://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=156357&action=wish_lists
and Finally, I am also considering custom water cooling a bit further down the track from even my later purchases, still not sure whether it will happen though, also due to the fact that parts are harder to come by here in Australia (as far as I am aware)
TL;Dr
Bitfenix Ronin, CM690II advance with window, or Tt Chaser A41? halp.
