Case under $60(hopefully)
I'm looking for an ATX case that is under $60(hopefully) any suggestions?
I probably won't be adding much to it other than the normal components.
Here's the guts I will be putting inside:
http://pcpartpicker.com/user/Skreedles/saved/3nVI
Question number 2:
What's the deal with the cube cases(I don't know the name of them).
How are they compared to tower cases, do they have better or worse airflow?
I think they look cool, especially because they are different.
for the pc, don't get the corsair vengeance ram, i have them on my pc, and with amd they work very bad. for the case, you can buy the cooler master 410 elite or the corsair 200r/300r... (if you are interested, i can give you some sugestion for the pc) as far as i know, the cube atx case, are a bit expensive(like the cooler master haf xb 150$) but because they "divide" the component into 2 chamber, like the power supply in the lower chamber and the mobo in the upper chamber, they offer better airflow, and maybe they can fit better than a tower pc
Another case to consider is the HAF 912. I got the Corsair 200R for a friend, and I didn't like it as good as the HAF 912. Cases are personal preference. Check out PCPartPicker and browse through the cases listed there. Use their filter options to stay within your budget.
http://pcpartpicker.com/parts/case/#sort=a8
I recommend you read some reviews and choose a case that you like. You'll also want to make sure it's compatible with your parts list. Pick a few out from the site above, and link us to them here. We can help you further from there.
http://www.walmart.com/ip/iBUYPOWER-NZXT-Source-210-USB-3.0-Gaming-Chassis-Red/29156721
a very nice case for the money
-Bitfenix Survivor
-Corsair 230T (if you can find a sale)
-Bitfenix Comrade
-Bitfenix Ghost
-Bitfenix Shadow
tt commander ms-I
nzxt source 210
