Whats up peoples. I need a new case since my case right now is a piece of crap. I have $150 to spend. The case has to be able to fit an ATI 4890. Any suggestions would be very helpful. Thank you all.
CM storm scout. or if you prefer your design to be simpler, Lianli PC-60fw :D
Yeh the coolmaster haf 932 is the way to go
Antec 900 or Antec 902
You gotta be looking for a long time to find such superior cases.
Antec 902 or 1200.
I have a sigma unicorn mid-tower case and it runs very cool. it runs 4 fans out of the box, two 120mm fans (one intake, one exhaust) along with two side LED 80mm fans. you can add another 80mm fan to the other side too. It's around $85 now, though it only holds a 10in card.
I'm using NZXT Tempest.
Great case, even though I'm getting 5x Noctua NF-S12B FLX (120mm fans) on monday, 'cause the stocks are too noisy for my mom
Why not get the Antec P-183, I'm thinking about getting one of those to swap for my CM690. Just a little bit over your budget, but its awesome, ok you have to like the design, but its also very silent and although it looks like if the cooling capabilities are very weak, it actaully is as good as a full tower CM Storm Sniper case. BUT watch out when you go crossfire... if you ever going to.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129061&Tpk=Antec%20P183
Heres a review:
http://benchmarkreviews.com/index.php?option=com_content&task=view&id=314&Itemid=61
It's a great case, but might be a little out of his budget.
btw.. (P182 looks alot better : 3)
Personally I wouldnt have a problem shelling out a little extra for something like that. Ok the P182 looks even more sleek then the P183 but the P183 has some advantages over it which makes me prefer it more then the previous version. Like better cooling and they got rid of some annoyances that came with the P182 that many people seemed to have problems with. Like the fan in the middle of the lower chamber, it made it hard for cable management etc... Oh well maybe with the shipping would make it cost to much.
Zalman Z3 plus - 70$, 360mm for the GPU...
Fractal Design Arc Midi R2 - 100$ GPU more than 400mm with the top HDD cage removed...
Fractal Design Define R4 - 100$ same thing...
Phanteks Enthoo Pro - 100$, 472mm GPU with the top cage removed
NZXT Phantom 410 - 100$ 305mm clearance with the cage, more then 400 without it
NZXT H440 - 120$ more than 400mm with HDD trays removed.
You have so many options, and those are all good cases within 120$...
