Case Recommendations
Anyone got a ideas on a case...
Currently Using a Fractal Arc Midi R2... even cut up it still doesnt fit everything
Needs to fix a Rampage IV Black (E-ATX), H110, 2 Tri-slot ASUS HD7970, 2 SSD's and 2 3.5" HDDs
Also attend may lan partys so would be nice if it where easy picked up
The Phanteks Enthoo Pro is a good case, its a very high quality feature rich case, I personally have one and I highly recommend it
Not bad...
a good case for LAN parties is the Cooler Master Storm Stryker, it's got a handle on it, and looks good. Another case made with LAN parties in mind is the Corsair C70.
As for cases with no handles or whatever, the Enthoo Pro is a good recommendation, and you can also look into the Corsair 760T. That case is made for showing off what you got inside it, and has some nice SSD mounts.
