Case mod and rebuild Coolermaster 690 II Advanced (reversed)
I finally finished my case mod and rebuilt my system.  I really like the Coolermaster 690 II Advanced, but it sits on my left and I wanted a right side access case.  I fabricated top, bottom, and front panels.  I used case handles, feet, and 3 fan grills from MNPCtech.  The other parts are found or repurposed from old systems (i.e. the 2 x USB 2.0 with front side audio and the 2 x 4 port USB 3.0 connections also up front.)  There are still 2 things I want to do.  The first is to make the USB 2.0 and audio jacks fit in better.  The second is to install a window mod on the side panel, but still have the fan there.  I look forward to your feed back.  FYI most of the wear/damage was on purpose because I like how it makes it look.
That looks so awesome, although the green PCB at the front kinda kills it but im sure that's not to hard but hey, its not my case
looks awesome love it love it love it so jelly
awesome!
Thank you guys.  The green PCB is the front side USB 2.0 and audio jacks from the original case.  I broke the USB 3.0 ports off of it and that is how I am running the 2 4 port USB 3.0 ports internally.  I am thinking of scrapping the USB and front audio since I don't use it anyway.
