Case Madness
I am going crazy tring to decide what case to get. I like all three of them and they are all different so I need help :P
Fractal Design XL
http://www.newegg.com/Product/Product.aspx?Item=N82E16811352017
Rosewill Thor V2
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147053
NZXT Switch 810
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146095
Also if anyone else has any other suggestions let me know.
I would recommend the switch 810, it's awesome and very easy to build in.
I also reccomend the switch. Very good case.
thor v2 has far better airflow than the switch.... and is $80 less..... and, IMO, looks better
I love the look of the 810, and The thor is nice but the interor of the 810 is just so much nicer.
how is it nicer? the interior is just that, a place to put parts...... though, i'd get the phantom 820 if it was $75 cheaper
have you looked at the coolermaster storm trooper(black)/stryker(white)? case is incredible. middle of the way price range for you too.
I dont know I am just crazy or something :P, but it does look good.
Yes, it is a nice case but I dont find its looks that pleasing.
how about the rosewill blackhawk ultra?
I have no need to go that big with an ATX mobo
but... but.. but.... bigger is better.....
CM HAF932?
you like square, flat stuff?
I know, bigger is better, but that case is freking HUGE, and the CM932 is nice but wouldn't match my room. and the NZXT 810 is square and flat but it has nice features. At least I dont want the 800D, that thing is a square with a window :P
I dont like rosewill cases, think there cheap garbage personally. There is a reason for the price ALWAYS. I think the switch looks better, is of better construction. I am not arguing bang for buck. Infact thats what I believe most, you are paying more for more. Less for less.
The switch is an awesome case. Had some hands on last weekend and some of the features blew me away. Almost bought one and I don't need a case but make no mistake this case is HUGE. Right up there with the Corsair Obsidian. Get the switch and be done with it. You won't regret it. This comes from someone who up until the switch didn't like NZXT cases.
I had hands om with the white windowed version though. Very sexy.
I went through this case decision thing a few weeks back and my brain hurt after a few days. So I understand how you feel.
