I'll try and make this problem as in depth as possible. Firstly, I recently switched my 7770 for an r9 270 yesterday (removed old drivers and installed new ones manually as amd auto detect didn't pick up my card, but all was well as msi afterburner displayed my version as r9 200 series.) and installed bf4 today. I was getting poor performance, freezing in loading screen and in game. Then I decided to play Dota 2 in the meantime as i was going to update my cpu to an i5 (current cpu intel pentium G860 which i believe might be the root of this problem) and near the end of the game my pc crashed and monitor says 'no signal detected' which happened once or twice in bf4(also in dishonoured some time ago but problem fixed itself). I then switched on my fd core 1000 case and the blue light came on but no fans came on and the pc didn't boot. I looked inside and the hard drive seemed on and the fans of the gpu were on but stock cooler fan was stationary which led me to believe that the cpu might be fried. What is the problem? Any help would be appreciated
Sorry, are the fans on the GPU working, but the Fans on your CPU heat-sink and rest of the case are not spinning??
Fans on GPU are working thank god, but cpu fan isn't
Front panel fan isn't either sorry
If the CPU fan isn't spinning the computer won't boot. What PSU are you using? The R9 270 is going to need more power than the 7770 it replaced. My best guestimate right now is that the PSU is half dead and needs to be replaced with something rated at 500W or more.
Xfx 550w 80+ bronze
