Case Labs TH10 Build Log
[quote]All aluminum construction - .090" (2.3mm) chassis .063"(1.6mm) doors/covers.
* Choice of ventilated or solid doors and covers (on a panel by panel basis). Right and left side windows are available in a variety of colors XL ($20.00).
* Slide out MB tray.
* Choice of one HDD cage assembly (4 drive capacity): either standard or flex-bay mount. Note that the flex-bay mount deletes one of the 3U filler panels.
* 13 Flex-Bays (5.25") + room for up to 16 HDD's
* Four single bay filler plates and three triple plates.
* Four sets of mounting brackets for 5.25” devices.
* I/O panel with firewire, four USB 2.0 ports, HD audio and microphone connection.
* Lamptron anti-vandal style switches and wiring harnesses: blue ring for power and red dot for HDD activity. They are standard switches that can be easily swapped out for custom color combination.
* Filler plates for top and bottom fan openings, 40mm fan openings on MB tray, card slots, and one PSU.
* Four rubber feet with screws (casters are available).
* Misc. hardware: Thumbscrews, MB standoffs, Tie-wraps, etc.
Case Dimensions (TH10) 15"W x 25.06"H x 26.06"D (381mm x 637mm x 662mm)
Rubber feet add .75" (19mm) to height, optional casters add 2.63" (67mm).
The TH10 supports HPTX boards
Supports Video Cards up to 17" (432mm) using Fan Mounts
Cooling tower clearance (measured from the top of the MB): 7.20" (183mm)[/quote] specs may change
[IMG]http://i1213.photobucket.com/albums/cc462/Juggalo23451/Case%20labs%20th10/IMG_0439.jpg[/IMG]
[IMG]http://i1213.photobucket.com/albums/cc462/Juggalo23451/Case%20labs%20th10/IMG_0438.jpg[/IMG]
[IMG]http://i1213.photobucket.com/albums/cc462/Juggalo23451/Case%20labs%20th10/IMG_0440.jpg[/IMG]
[IMG]http://i1213.photobucket.com/albums/cc462/Juggalo23451/Case%20labs%20th10/IMG_0441.jpg[/IMG]
[IMG]http://i1213.photobucket.com/albums/cc462/Juggalo23451/Case%20labs%20th10/IMG_0448.jpg[/IMG]
[IMG]http://i1213.photobucket.com/albums/cc462/Juggalo23451/Case%20labs%20th10/IMG_0447.jpg[/IMG]
[IMG]http://i1213.photobucket.com/albums/cc462/Juggalo23451/Case%20labs%20th10/IMG_0449.jpg[/IMG]
[IMG]http://i1213.photobucket.com/albums/cc462/Juggalo23451/Case%20labs%20th10/IMG_0450.jpg[/IMG]
[IMG]http://i1213.photobucket.com/albums/cc462/Juggalo23451/Case%20labs%20th10/IMG_0451.jpg[/IMG]
[IMG]http://i1213.photobucket.com/albums/cc462/Juggalo23451/Case%20labs%20th10/IMG_0453.jpg[/IMG]
This case is definitely massive can fit 4 480 rads internally. You could fit a 480 rad in the front and a 360 or another 480 in the front. 2 psu if need as well. Build quality is exceptional. Packaging for the case as you can tell from the pics was great.they went into great detail to protect this case. It took me about 20 min or so to remove this protective film on the case.
How'd you get it in white? I thought they were only making these in black.
>Click link
>Oh just an average case I don't see anyth--
[img]http://img577.imageshack.us/img577/2633/1296006202576.jpg[/img]
I-It's beautiful....
They will do white cases in the near future.
Rabu Rabu said:
>Click link
my exact reaction 0_o
That case looks "phenomenal"! as trubritar would say.
What do you plan to do with it?
[IMG]http://i1213.photobucket.com/albums/cc462/Juggalo23451/Case%20labs%20th10/IMG_0457.jpg[/IMG]
Oh sweet Jesus it's bigger than my bathroom.
What type of paint did they use? It looks so glossy.
http://www.youtube.com/watch?v=qIb_iHH1jqM
You can fit a elephant in there.
that's a one lonely motherboard
[img]http://img152.imageshack.us/img152/4912/1239337207343.png[/img]
do continue....
http://www.youtube.com/watch?v=eGrmeWTmOc0
If only nzxt had done this with th ephantom design. i love my phantom, but got damn i love this more.
Looks nice, but I'm wondering how the power supplies are going to be able to sit without falling, bending the case, or wearing down the screws over time. Is there some kind of a mounting system for the PSUs?
http://www.youtube.com/watch?v=VDD164O3pHY
[IMG]http://i1213.photobucket.com/albums/cc462/Juggalo23451/GTX%20590/IMG_0459.jpg[/IMG]
[IMG]http://i1213.photobucket.com/albums/cc462/Juggalo23451/GTX%20590/IMG_0460.jpg[/IMG]
[IMG]http://i1213.photobucket.com/albums/cc462/Juggalo23451/GTX%20590/IMG_0461.jpg[/IMG]
[IMG]http://i1213.photobucket.com/albums/cc462/Juggalo23451/GTX%20590/IMG_0466.jpg[/IMG]
[IMG]http://i1213.photobucket.com/albums/cc462/Juggalo23451/GTX%20590/IMG_0467.jpg[/IMG]
Youre not gonna have them that close to each other I suppose?
FAP FAP FAP FAP FAPFAPFAPFAPFAP........OHH GODD!
Yes, I am water cooling them.
I envy you, sir.
