Case Help
I posted this under "Case" but there were no replies so I will post it here.  Hey I was wondering if the NZXT source 210 case will be able to fit a CM hyper 212 EVO heatsink? THX!
Well the case is 195mm wide, and the cooler is 120 x 80 x 159mm so I think you should be fine.
