Case help please
i'm about to build my first pc. i'm currently looking at a zalman z11 and i'm wondering if their is a case thats around the same price with an internal usb 3.0 header that still had a decent amount of fans and looks good
I'd grab a Fractal Design Arc Midi R2, which is $64.99 on NCIX, right now.
Great airflow, solid looks, and built well :)
i'm from the uk so the pricing may be slightly different but i'll check it out. thank you
Fractal cases are a pretty reasonable price in the UK. I'd recommend them
i really like the look of the r4. also just spotted a corsair carbide 300r about 20 than most of the fractual design cases. would that be a good option to?
Corsair and Fractal are both good options.
thank you. the help is much apperciated
