Case for Water cooling
Planning to build a water cooled computer, and i need som advice on cases.
Criteria:
Widowed (preferbaly large)
Room for dual 120mm Rad and a triple or dual 120mm rad
At least 4 5,25 Bays
Bottom mounted PSU
Please discuss, and give differnet suggestions
My favorite case so far (on paper/pictures) is the NZXT Tempest 410, but it's one 5.25 bay short.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146080
Another option from NZXT is the Switch 810
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146089
Otherwise, there is the Corsair Obsidian series (650D seems the most reasonably priced)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139006
Those are the best options I found on the egg without going upwards of $200
Silverstone has great options, like this one
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163217&Tpk=silverstone%20tj07
