I wanted some suggestions on a case for Star Citizen because I was planning on doing some modifications to it. I'm ruling out the Cosmos mostly do to price. The case would have to be ATX compatible, but mid and full tower cases are fine. So pretty much the case should have a space theme look to it, or have the potential for it. Thank you!
the nzxt phantoms look kinda spacey i guess.
Ok here are some full cases, that are kinda of spacey maybe..
http://www.newegg.com/Product/Product.aspx?Item=N82E16811322017
http://www.newegg.com/Product/Product.aspx?Item=N82E16811322047
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156284
Now for some mids
You could probably throw a Star Citizen symbol on the fan in the front of this or something..
but it is rather basic
http://www.newegg.com/Product/Product.aspx?Item=N82E16811208043
multiple colors on this one
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156268
some color choices for this one as well, you just have to find them..They are not listed through a drop down menu..
http://www.newegg.com/Product/Product.aspx?Item=N82E16811144288
more color choices here you have to find them again also there are 3 gauges in those (illuminated? not sure) bubbles
http://www.newegg.com/Product/Product.aspx?Item=N82E16811144282
http://www.newegg.com/Product/Product.aspx?Item=N82E16811108395
please for all that is holy dont buy raidmax..... just plz.......
Are they bad??I just put up some links to some Sci Fi space looking stuff..
one of their PSUs started on fire in one of my PCs. had one of their cases. come with broken fins on the side of it. No customer support and no willing nice to correct their screw ups.
Well that is not cool..You are giving me the fear I have a Raidmax RX-850AE 80 Plus Gold Power Supply had it for almost a year now with no problems yet..
http://www.techoftomorrow.com/2013/pc/tot-customs-water-cooled-tron-system-final-build-gallery/
Slightly off topic, but this is similar...
You should be fine, all depends on luck. Using Raidmax 735w 80+ bronze for a while.
ive had alot of their parts that were unbranded versions used in pre-built systems. I refuse to use their products and advise everyone to stay away from them....o and did i say one of their PSUs i had started on fire? well....ya it did.....brand new out of the box started smoking and caught fire....
