I just completed my first build and I still have to buy case fans to replace the stock ones. One thing I don't understand is PWM vs. Voltage controlled fans and the difference between 3 and 4 pin. My mobo is a Hero VI which after researching has only one PWM fan header which is the CPU fan. I have no idea what that means but can someone tell me what the best way would be to plugin my fans? I have 2 fans on my H100i and 3 case fans.
Possible places for connecting fans:
-H100i
-Mobo CHA_FAN
-Mobo CPU_FAN CPU_OPT
-Case fan controller
What is the best config? Also in regards to my system, which case fans would be extremely quiet but also good performers? No budget.
