Case fan mods
I need to my mod Kandalf 9000 case to hold a 240mm rad in the front. Anyone know any pre-fabbed mods that will make this simple? The case was designed to hold 3 120mm fans in the front, but you need a drive cage with a fan mount to mount them. The case comes with one and you could order more...6 years ago. The reason why I want to mod this case and not get a new one is because how huge it is. It's a E-ATX case that I got from a friend. It's easily a 150+ USD case, and it's quite awesome. If you have time look it up. It's a thermaltake Kandalf 9000. I have the non-LCS version and the black one.
So, any suggestions for a mod that can hold a 240mm rad?
No answer must mean, "You are on your own. Good luck bro".
not really, just means we didn't see your post. pre-fab mods really don't exist. you will probably need to make your own bracket
I might have to. And it has non-removeable toolless 5.25 drive cage
could you not just drill out the rivets on the drive cage and pop it out (then mod it to take the 240mm and rivet the cage back in? pop rivet guns are only about £5)
he has the room, just not the supports for it. just needs a bracket to mount it to
