Hi Everyone, new to the site here and I was wondering if I could ask a question.
I'm looking at purchasing the Fractual Design Define R4 Black Pearl case in the new year and I was wondering if my my components will fit inside this case, my components will be listed at the bottom of this message but my main concern is weather my CPU cooler will fit in the case, it is a Thermalright HR-02 Macho Rev.A CPU Cooler for Intel and AMD with a 140mm silent fan and in my current case (Antec 902 pre USB 3.0) It only just fits, So I was wondering if someone can advise me on this matter please.
I looked up your cpu cooler and it is apparentely 162mm tall, the r4 product page says it has room for 170mm max cpu coolers so you should have 8mm which isnt much. I wouldn't worry too much about it but I'd still look at other cases.
Yea 8mm clearance isnt much what other cases would you recomend? I'd like to keep the minimalistic theme of the R4 along with the quiet case qualitys, one thing I really want though is air filters be be attatched to it from supplyer and to be able to have easy acces to removing and cleaning the air filters, currently I have to half take appart the whole case just to clean the air filters, oh and enough space to fit the biggest of GPU's too.
