Building a new computer for a friend (who will use it primarily for gaming) and wondering which pair of sticks will give better performance if any at all.
1600 Mhz @ 9 Cas Latency
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148544
1333 Mhz @ 7 Cas Latency
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148485
What will you be doing other than gaming? The difference between the two is literally half a frame (if that) when gaming.
They will be just browsing the web, homework, music, movies, and ect. Nothing that really takes performance other then gaming
In that case, I would go for the 1600 Mhz ram, as it is a few dollars cheaper and looks better aesthetically in my opinion.
