Hi,
I hope it’s ok to ask for help even though i’m not super technical. Pretty much a script kiddie, but not a kid.
Everything is running fine on a VM i installed Windows 10 Pro on with latest LG. Ubuntu 22.04 is the host.
When I clone that machine I get a blank screen when I start it. I kept a copy of a VM with no LG and just GPU passthrough and it clones and starts fine.
Here is the terminal print out from the host when I try to connect to the LG VM clone.
./looking-glass-client
[I] 110685063559 main.c:1785 | main | Looking Glass (B6)
[I] 110685063581 main.c:1786 | main | Locking Method: Atomic
[I] 110685083470 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 9 3900X 12-Core Processor
[I] 110685083478 cpuinfo.c:38 | lgDebugCPU | CPU: 1 sockets, 12 cores, 24 threads
[I] 110685102193 main.c:1162 | lg_run | Using font: /usr/share/fonts/truetype/dejavu/DejaVuSansMono.ttf
[I] 110685102515 ivshmem.c:128 | ivshmemOpenDev | KVMFR Device : /dev/shm/looking-glass
[I] 110685107164 audio.c:159 | audio_init | Using AudioDev: PipeWire
[I] 110685107184 ps.c:245 | purespice_connect | Connecting to socket 127.0.0.1:5900
[I] 110685115218 rsa.c:178 | rsa_encryptPassword | Using Nettle
[I] 110685115635 ps.c:268 | purespice_connect | Connected
[I] 110685115727 channel_main.c:167 | onMessage_mainName | Guest name: win10-clone1
[I] 110685115764 channel_main.c:183 | onMessage_mainUUID | Guest UUID: 9f74fad8-2bd2-4881-9b46-1eb440c8d1b6
[I] 110685121502 ps.c:644 | ps_connectChannel | INPUTS channel connected
[I] 110685121552 channel.c:312 | onMessage_notify | [notify] keyboard channel is insecure
[I] 110685121628 egl.c:267 | egl_initialize | Double buffering is off
[I] 110685121646 main.c:1116 | tryRenderer | Using Renderer: EGL
[I] 110685122507 x11.c:230 | x11CheckEWMHSupport | EWMH-complient window manager detected: GNOME Shell
[I] 110685122684 x11.c:463 | x11Init | X11 XInput 2.0 in use
[I] 110685130740 x11.c:1433 | x11GetEGLDisplay | Using eglGetPlatformDisplayEXT
[I] 110685145441 egl.c:745 | egl_renderStartup | Multisampling enabled, max samples: 4
[I] 110685149968 egl.c:828 | egl_renderStartup | Single buffer mode
[I] 110685170589 egl.c:855 | egl_renderStartup | EGL : 1.5
[I] 110685170621 egl.c:856 | egl_renderStartup | Vendor : NVIDIA Corporation
[I] 110685170650 egl.c:857 | egl_renderStartup | Renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
[I] 110685170678 egl.c:858 | egl_renderStartup | Version : OpenGL ES 3.2 NVIDIA 515.86.01
[I] 110685170709 egl.c:859 | egl_renderStartup | EGL APIs: OpenGL_ES OpenGL
[I] 110685170755 egl.c:930 | egl_renderStartup | Debug messages disabled, enable with egl:debug=true
[I] 110685187014 eglutil.c:35 | swapWithDamageInit | Using EGL_KHR_swap_buffers_with_damage
[I] 110685378195 main.c:1467 | lg_run | ================================================================================
[I] 110685378232 main.c:1468 | lg_run | The host application seems to not be running
[I] 110685378264 main.c:1469 | lg_run | Waiting for the host application to start...
[I] 110714380064 main.c:1474 | lg_run | ================================================================================
[I] 110714380125 main.c:1488 | lg_run | Check the host log in your guest at %ProgramData%\Looking Glass (host)\looking-glass-host.txt
[I] 110714380166 main.c:1489 | lg_run | Continuing to wait...
I can’t get to the LG host/Windows guest to get anything to provide you with. If someone could point me in the right direction to provide anything else that could be useful.
Should I try an earlier version of LG?
thankyou,
Frink
