I pulled 8 drives out of a working synology unit. The drives are good but I no longer have the synology. They were a shr5 btrfs raid with no encryption only 1 storage pool/volume for all drives DSM v7.1. I don’t need RW access, if I can mount read only that will work.
I followed each step in the synology official guide (cant link it).
kb.synology DOT com/en-us/DSM/tutorial/How_can_I_recover_data_from_my_DiskStation_using_a_PC
When I try to run the first mdadm command (step 11 in their guide) it fails and prints “mdadm: No arrays found in config file or automatically.”
fdisk -l output:
Disk /dev/sda: 3.7 TiB, 4000787030016 bytes, 7814037168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 1F6155F2-4057-47E0-8EEE-146C4FE45620
Device Start End Sectors Size Type
/dev/sda1 2048 4982527 4980480 2.4G Linux RAID
/dev/sda2 4982528 9176831 4194304 2G Linux RAID
/dev/sda5 9453280 7813830239 7804376960 3.6T Linux RAID
Disk /dev/sdb: 3.7 TiB, 4000787030016 bytes, 7814037168 sectors
Disklabel type: gpt
Disk identifier: 06963498-AB74-49F5-AD88-2ACFBBFF593A
/dev/sdb1 2048 4982527 4980480 2.4G Linux RAID
/dev/sdb2 4982528 9176831 4194304 2G Linux RAID
/dev/sdb5 9453280 7813830239 7804376960 3.6T Linux RAID
Disk /dev/sdc: 3.7 TiB, 4000787030016 bytes, 7814037168 sectors
Disklabel type: gpt
Disk identifier: CF965790-5FB6-4058-AC97-48D1E856B8FD
/dev/sdc1 2048 4982527 4980480 2.4G Linux RAID
/dev/sdc2 4982528 9176831 4194304 2G Linux RAID
/dev/sdc5 9453280 7813830239 7804376960 3.6T Linux RAID
Disk /dev/sdd: 3.7 TiB, 4000787030016 bytes, 7814037168 sectors
Disklabel type: gpt
Disk identifier: 493AAED9-917E-46BD-84E4-1F9247325F1F
/dev/sdd1 2048 4982527 4980480 2.4G Linux RAID
/dev/sdd2 4982528 9176831 4194304 2G Linux RAID
/dev/sdd5 9453280 7813830239 7804376960 3.6T Linux RAID
Disk /dev/sde: 3.7 TiB, 4000787030016 bytes, 7814037168 sectors
Disklabel type: gpt
Disk identifier: 82CE97A9-FBE2-410F-863D-1C055ED315B7
/dev/sde1 2048 4982527 4980480 2.4G Linux RAID
/dev/sde2 4982528 9176831 4194304 2G Linux RAID
/dev/sde5 9453280 7813830239 7804376960 3.6T Linux RAID
Disk /dev/sdg: 3.7 TiB, 4000787030016 bytes, 7814037168 sectors
Disklabel type: gpt
Disk identifier: FC79D7BE-BB98-4196-BC98-DA61E9941ADF
/dev/sdg1 2048 4982527 4980480 2.4G Linux RAID
/dev/sdg2 4982528 9176831 4194304 2G Linux RAID
/dev/sdg5 9453280 7813830239 7804376960 3.6T Linux RAID
Disk /dev/sdf: 3.7 TiB, 4000787030016 bytes, 7814037168 sectors
Disklabel type: gpt
Disk identifier: 20593F34-7781-4506-9CF6-44DC77684480
/dev/sdf1 2048 4982527 4980480 2.4G Linux RAID
/dev/sdf2 4982528 9176831 4194304 2G Linux RAID
/dev/sdf5 9453280 7813830239 7804376960 3.6T Linux RAID
Disk /dev/sdh: 3.7 TiB, 4000787030016 bytes, 7814037168 sectors
Disklabel type: gpt
Disk identifier: 7509D6B6-4B08-4DCB-A2AF-5EBDE71A7345
/dev/sdh1 2048 4982527 4980480 2.4G Linux RAID
/dev/sdh2 4982528 9176831 4194304 2G Linux RAID
/dev/sdh5 9453280 7813830239 7804376960 3.6T Linux RAID
Would love to know where to go from here. Thanks.
