Basicly, I'm trying to plan a build for a low budget gaming PC. Budget is ~$430 CAD and the PC would be used for mostly gaming. I play games such as; League of Legends, WOW, Dota II, Minecraft, Magicka and I would also like to play Supreme Commander 2 or SC2. My display is 1360 by 768.
I had some sort of idea for two different builds:
Build 1: http://pcpartpicker.com/ca/p/pvpZ (FX-6300 build)
Build 2: http://pcpartpicker.com/p/pvMm (i3 build)
Feel free to make changes or suggest me a new build completely.
EDIT: BUDGET IS NOW $500 CAD
is it possible to go up to $500 or can i go with a little more money
Sure, I guess i can squeeze it up to $500
if your going with the a-10 go with a 6670, the 7xxx series cards don't appear to crossfire with them. All I'm seeing is that it crossfires with is a 6670.
http://www.pureoverclock.com/Review-detail/amd-trinity-a10-5800k-review/
http://www.amd.com/us/products/technologies/dual-graphics/Pages/dual-graphics.aspx#3
check this build out i think you would like it more http://pcpartpicker.com/ca/p/plFD
Should I get an i3 or the FX-6300? I will update the two builds for a $500 CAD budget
if u are just gaming i dont see the point of the 6300, i would rather go with the 4170 it has 2 less core but a higher clock rate, the two extra cores the 6300 give u would only really help in rendering and 3d modeling type programs
no zambezi is not that great go with at least the 4300 or for $10 more go for the 6300 i dont see any reason not to get it just incase you do want it
Alright, I'm going with the 6300. Thanks guys.
