I have a USB HDD enclosure which supports USB 3.1 and a Minisforum HM90( Ryzen 9 4900H) running Ubuntu 22.04 LTS. The USB cable is the one included with the enclosure and plugged into a 3.1 port on the HM90.
However, I cannot mount the device. It seems like the usb device keeps getting reset according to dmesg:
[ 104.483543] usb 4-2: reset SuperSpeed Plus Gen 2x1 USB device number 2 using xhci_hcd
I tested the enclosure on another Intel PC and it worked without issue. I suspect it’s some driver issue or some quirk with AMD. I tried to blacklist UAS but it didn’t work:
# lsusb
Bus 004 Device 003: ID 174c:1356 ASMedia Technology Inc. ASM1352R-Volume
# cat /etc/modprobe.d/disable-uas.conf
options usb-storage quirks=174c:1356:u
# dmesg
[ 1537.580821] usb 4-2: UAS is ignored for this device, using usb-storage instead
[ 1537.580824] usb-storage 4-2:1.0: USB Mass Storage device detected
[ 1537.581068] usb-storage 4-2:1.0: Quirks match for vid 174c pid 1356: 800000
[ 1537.581161] scsi host2: usb-storage 4-2:1.0
I also disabled legacy USB support in the bios.
I am at a loss for what to do, any ideas?
