I have a RTX 3090 which has 3 Display Ports and 1 HDMI port. I used a Display Port to HDMI conversion cable and am unable to get the HDMI port on my 3090 to show the 4th monitor. I have searched the forums and the main install thread and am not finding anything about this. Is there a way to get the HDMI port on my 3090 to work with the 1.4 Display Port KVM?
I am connecting to LG 4K UHD 27UD88-W 27" LED-Lit Monitor with the following specs
OK thank you for the help, I am buying one of each of these to test out and see which gives the better performance. I posted links for others that may have the same question.
120hz USB Powered
Some people report glitch’s with the 120hz in the reviews, it is possible they may have pulled the product since i can not find it on Clubs website https://www.amazon.com/DisplayPort1-4-HDMI-4K120Hz-Active-Adapter/dp/B08BC8LV3M
Club CAC-1085 USB C powered 120hz - https://www.club-3d.com/en/detail/2496/displayport_1.4_to_hdmi_4k120hz_hdr_active_adapter_m-f/
This seems to be a newer supported model but again, people report issues saying it’s great when it works and the power has to be unplugged and repluge when changing from Full screen games to normal screen.
Club # CAC-1331 60Hz https://www.amazon.com/Club-3D-DisplayPort-Video-Adapter/dp/B085YBR936/ref=sr_1_3?crid=23JC5QI5JFZXT&keywords=Club+3D+4K+60Hz+HDMI+to+DisplayPort&qid=1661194897&s=electronics&sprefix=club+3d+4k+60hz+hdmi+to+displayport%2Celectronics%2C360&sr=1-3
