I've got a python script running with a touch display connected via serial. I have several prompts in it, which I can answer either:
1. In a shell
2. With display buttons
I'd like to be able to do either, without rewriting the functions each time, with whichever is first overriding the other.
Lately, my approach has been to find and kill the pid of the stdin input process ("lineread") when a button is pressed, though I'm positive that there's a better way that I'm unaware of. Plus, it doesn't work, anyway. Pressing the display button twice will advance the script (ignoring errors), but then the input won't actually work when Enter is pressed.
"displayRead" just reads the display for input and puts the action in a queue.
I thought maybe I could do something with killing procs via a joinable queue, but I'm unsure how (or what I was thinking, exactly).
Anyone have any thoughts or know how to do this?
Messy code warning (I'm new)...
import serial
import signal
import sys
from time import sleep
import os
from multiprocessing import Queue,JoinableQueue,Process
debug = True
def inputOverride(q,interrupt):
while True:
standby = q
output = standby.get()
if output:
killpid = interrupt.get()
if debug:
print("Killing:\t\t", killpid)
try:
os.kill(killpid, signal.SIGTERM)
except Exception as e:
pass
def waitForInput(q,interrupt):
if debug:
print("Input PID:\t\t", os.getpid())
interrupt.put(os.getpid())
try:
reply = input().lower()
if reply in ["n", "no"]:
q.put("n")
else:
q.put("y")
return
if debug:
print(e)
return
def firstReply():
if __name__ == '__main__':
answer = Queue()
interrupt = JoinableQueue()
display = Process(target=displayRead, kwargs={"out":answer, "yn":True}, daemon=True)
override = Process(target=inputOverride, args=(answer,interrupt), daemon=True)
lineread = Process(target=waitForInput, args=(answer,interrupt))
procs = [display,override,lineread]
for p in procs:
p.start()
output = None
while True:
if output:
([p.terminate() for p in procs])
if debug:
print(output)
break
elif not output:
if not answer.empty():
output = answer.get()
continue
# There used to be more crap here but it wasn't working right
return output
