Please let me know if i should change anything. Im aware i have no OD and PSU. Please help me find a good Corsair/Seasonic PSU that is not too high watts, and not too low (because i heard if you have too many watts, it wont utilize the leftover watts, making it less efficient)
http://pcpartpicker.com/p/1IJ8I
Get the HD 7970. It'll outperform the 770, and is cheaper
I got the XFX PRO550W PSU. It's made by Seasonic, cheap, and doesn't have any coil whine. It'll fit your build perfectly. It's not modular, but if I can wire it inside my Mini-ITX Node 304, I'm sure you'll be able to pull it off in the NZXT case
http://pcpartpicker.com/part/xfx-power-supply-p1550sxxb9
