would cost me ~700€ without the case (without the case cause my local shop does not offer it)
edit::
http://pcpartpicker.com/p/JzYn
(added a new case)
<removed the 2nd option>
or can you recommend something better for around 800€?
edit::
(added a new case)
Why you want a mini tower case with micro atx mainboard?
the first setup is realy fine, only i would chance the mainboard. to a better one.
do you gonne overclock or do you gonne run it on stock speeds?
for overclocking people here say the Gigabyte GA970 UD3 is a great board.
http://pcpartpicker.com/p/JtOS
i personaly like the Asus M5A97 r2.0 to...
http://pcpartpicker.com/p/JyEf
1st one, the 2nd one's mobo doesnt have sata 6gb/s
As I am new to this, I won't be overclocking.. I guess.
Uh can you tell me why the asus mainboard is better?
im not realy an asrock fan, but the boards arent that bad only better not overclock it..
if you wanne go do some things with overclocking then the Gigabyte board i posted is the best choise bord to but in the 970 chipsets.
has to do with cpu powering 4+4 pin or 8+2 pin power on the gigabyte is better for overclocking, thats what most people are saying here.
I see..but I heard that the Gigabytes Motherboards need a bios updates to work with the FX-6300 do you know anything about that?
Another question do I need a Cooler Master Hyper 212 EVO if I want to overclock or is the CPU fan that comes with the CPU enough?
