So while building a pc i decided to buy these stuff :http://uk.pcpartpicker.com/p/3eiAP
and the one decision I CANT PUT MAH FINGER ON IT is the case ..... yes the case so i will tell which cases i am considering to buy soo i between the nzxt h440 and the nzxt 530 also you can suggest me any other cases which have a black/red color pattern it would be appreciated :D
might want to doublecheck that the ram has clearance for those massive heatsinks on it... the 212 EVO is BIG, so I've always used low profile ram with it (granted I've never tried to stuff ram with big heatsinks underneath it, but still.... worth noting)... also might want to revisit your PSU... the Corsair CX line is kind of low end and you're not coming anywhere near 750w... a 450-500w PSU is all you'll need for that system and you could afford a Seasonic or XFX at that price point...
as for the case... the h440 is kind of sexy... otherwise I might be tempted just get a Define R4 w/ window, replace the fans and paint the slot covers... but that's my personal opinion... nobody can really tell you what case YOU think looks good yano.... the Define R4 is really high quality all around and has tons of cable stashing options though...
Why get a Z87 board with a non-K CPU? You can save a few more quid if you went with the B based boards.
The 212 Evo heatsink isn't that big. I don't even think you'll be using the DIMM slot closest to the CPU.But it's always a good idea to check for clearance prior,though
Yeah he will be fine as long as they are in slots 2 and 4 and he just sticks with 8GB of that set. If he wanted to go 16GB, I know G. Skill Ares will fit under a 212 but he would have to find a color he liked, or find a set the same size as the Ares.
