I’m wondering about tech in the works that Looking Glass could possibly replace DXGI capture with in the future. Anything y’all know about?
Uhhh, the only alternative I know of is NVFBC.
DXGI is an internal component of either the GPU drivers or the OS itself.
I don’t think we can simply write code to replace it.
We can only hope that MS patches it to make it more performant.
Or you can buy a quadro.
There’s AMD’s Direct GMA tech but that’s once again only on workstation cards:
Also AMD DOPP, but again, workstation cards only.
