Hello people!
After I finally succeeded in building Looking Glass I am now trying to getting it to run in a VM → VM config. After I had issues with B5.0.1, I decided to try the git version.
Note: I am using Linux Mint [email protected] 6.0.9-060009-generic (Cinnamon) and trying to passthrough keyboard, mouse, display and – if possible – audio from a Win10 VM on a “server” running PVE 7.x. with Looking Glass.
Looking Glass does compile, but installing the modules following the documentation fails.
sudo dkms install "."
Creating symlink /var/lib/dkms/kvmfr/0.0.8/source -> /usr/src/kvmfr-0.0.8
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area...
make -j4 KERNELRELEASE=6.0.9-060009-generic KDIR=/lib/modules/6.0.9-060009-generic/build...
Signing module:
- /var/lib/dkms/kvmfr/0.0.8/6.0.9-060009-generic/x86_64/module/kvmfr.ko
Secure Boot not enabled on this system.
kvmfr.ko:
Running module version sanity check.
- Original module
- No original module exists within this kernel
- Installation
- Installing to /lib/modules/6.0.9-060009-generic/updates/dkms/
depmod...
So compiling seems to have worked but when I load the module with
sudo modprobe kvmfr
I get the return:
modprobe: ERROR: could not insert 'kvmfr': Exec format error
What do I need to do differently?
Greetings & thank you for trying to solve these issues on Layer8 in advance
goldsteal
Update: Added info on Desktop Enviroment (Cinnamon). I think it runs Wayland but I am not certain. Will check.
