Hello! I built my new pc today. (Wohoo!) I was just wondering, is it possible that statical electricity can disable/destroy USB ports but still boot up fine and work with other USB ports.
I'm using the AsRock Extreme4 LGA1155, motherboard. The top two USB 3.0 ports aren't working (if I plug some device to the port it doesn't get recognized by windos. The other four USB ports work fine.
It doesn't always just flat out kill the board. You can damage certain areas of the board, and I know a lot of newer boards have ways of isolating damage so that the static shock doesn't spread throughout the entire board in order to minimize the damage done to the board. It is entirely possible to hurt USB 3.0 and nothing else.
my A+ course work says that a single static shock carries 10 times the amount of electricity required to fry motherboard components.. this is why you always ground yourself before touching components.
Hey, it's me again. So in the same category that can statical electricity destroy anything; is it possible to screw up the motherboards abilitie to read ram speed (Mhz)?
this my friend, is not a static electricity issue. its purely software, first. download the USB drivers from the manufacturer. just Google the manufacturers name, click their website, there'll be a tab at the top of the site, its gonna say either 'downloads' 'drivers' or 'support' find/select/use the search bar to find your motherboard, *your motherboard* if you can't find it, click my name, then the tab that says 'contact' and put your motherboards information into the message and I'll link the driver you need back to you. as for the RAM speed- many motherboards downclock RAM by default. you'll need to manually reset the speeds to the proper rate.
