Can someone help put together a build?
Can someone put together the best gaming computer the max budget is 1000$, I would like to keep it at 950 or less though. Thanks for helping!
any help?
Have a little patience, because it takes some time to build these up.
Intel Build:
[url=http://pcpartpicker.com/p/Ti6Y]PCPartPicker part list[/url] / [url=http://pcpartpicker.com/p/Ti6Y/by_merchant/]Price breakdown by merchant[/url] / [url=http://pcpartpicker.com/p/Ti6Y/benchmarks/]Benchmarks[/url]
[b]CPU:[/b] [url=http://pcpartpicker.com/part/intel-cpu-bx80637i53570k]Intel Core i5-3570K 3.4GHz Quad-Core Processor[/url] ($219.99 @ Amazon)
[b]CPU Cooler:[/b] [url=http://pcpartpicker.com/part/cooler-master-cpu-cooler-rr212e20pkr2]Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler[/url] ($32.99 @ Newegg)
[b]Motherboard:[/b] [url=http://pcpartpicker.com/part/asrock-motherboard-z77pro3]ASRock Z77 Pro3 ATX LGA1155 Motherboard[/url] ($79.99 @ Newegg)
[b]Memory:[/b] [url=http://pcpartpicker.com/part/gskill-memory-f314900cl9d8gbsr]G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory[/url] ($60.30 @ Newegg)
[b]Memory:[/b] [url=http://pcpartpicker.com/part/gskill-memory-f31866c9d8gab]G.Skill Ares Series 8GB (2 x 4GB) DDR3-1866 Memory[/url] ($64.99 @ Newegg)
[b]Storage:[/b] [url=http://pcpartpicker.com/part/western-digital-internal-hard-drive-wd10ezex]Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive[/url] ($66.68 @ Amazon)
[b]Video Card:[/b] [url=http://pcpartpicker.com/part/sapphire-video-card-1003523l]Sapphire Radeon HD 7950 3GB Video Card[/url] ($289.99 @ Newegg)
[b]Case:[/b] [url=http://pcpartpicker.com/part/corsair-case-300r]Corsair 300R ATX Mid Tower Case[/url] ($49.99 @ Newegg)
[b]Power Supply:[/b] [url=http://pcpartpicker.com/part/corsair-power-supply-cx500]Corsair Builder 500W 80 PLUS Bronze Certified ATX12V Power Supply[/url] ($44.99 @ Newegg)
[b]Optical Drive:[/b] [url=http://pcpartpicker.com/part/lite-on-optical-drive-ihas124-04]Lite-On iHAS124-04 DVD/CD Writer[/url] ($17.99 @ Newegg)
[b]Total:[/b] $927.90
[i](Prices include shipping, taxes, and discounts when available.)[/i]
[i](Generated by PCPartPicker 2013-04-26 23:31 EDT-0400)[/i]
AMD Build:
[url=http://pcpartpicker.com/p/Ti94]PCPartPicker part list[/url] / [url=http://pcpartpicker.com/p/Ti94/by_merchant/]Price breakdown by merchant[/url] / [url=http://pcpartpicker.com/p/Ti94/benchmarks/]Benchmarks[/url]
[b]CPU:[/b] [url=http://pcpartpicker.com/part/amd-cpu-fd8350frhkbox]AMD FX-8350 4.0GHz 8-Core Processor[/url] ($194.15 @ Amazon)
[b]Motherboard:[/b] [url=http://pcpartpicker.com/part/asus-motherboard-m5a99fxpror20]Asus M5A99FX PRO R2.0 ATX AM3+ Motherboard[/url] ($134.99 @ Newegg)
[b]Total:[/b] $957.06
[i](Generated by PCPartPicker 2013-04-26 23:35 EDT-0400)[/i]
Thanks for the builds
Your welcome. Which one do you like?
Both, Still deciding but both are pretty good.
Just throwing my 2 cents in... That Asus M5A99FX Pro R2.0 board is very good.
Do you own that Mobo Sylo32?
