I was playing battlefield 4 and my computer just restarted by itself, then it started restarting with outher games that i never had does type of problems with. thanks
Might be your PSU. When the voltage is too low on a PSU and you run something that causes your components to draw more power that you have, the computer will usually shutdown.
If your comp worked just fine on games before trying out BF4 and is now having problems, one of the components might have gone bad (possibly the PSU).
HWinfo + the OSD feature of Afterburner. There is a thread on some forum that describes hwo to set them up together, but that will allow you to monitor your temps and just about anything else you want. As far as recording them goes, I don't know. HWinfo remembers the max, but other than that, I don't know.
What I think could be the problem is that you either have a problem with overheating, or you have some faulty hardware. I highly doubt that your system is taking more than 650W, so if it is the fault of the psu, then it is because it is faulty. It could also be something in your motherboard. A faulty unit, or it could have just given way under the load of the temps of playing BF4. Watch your temps while gaming, and if they don't get dangerously high, and it still does the same thing, then investigate other things.
I heard him say that and said 'oh, shit', using the same CPU as OP & already having run prime for over an hour after various OC set-ups. But apparently with good cooling (I only have an H60 as well) it should be fine. OP and I have very similar rigs 'cept my GTX660 is a mini-beast, love it.
BF4 recommends "A modern DX11 graphics card with 2+ GB of video memory, GeForce 600 series or Radeon 7000 series "
aida 64 engineer is a monitoring and stress test program that is specifically designed to be used with Ivy bridge and later CPUs. I've heard JJ from ASUS say that prime shouldn't be run on Ivy because it doesn't effectively test all of your CPUs perimeters. Or something like that.
edit: it might be said by some that you could have been trying to kill your CPU by running BF4 as a brand new un-optimized game without a discrete graphics card.
H60 is fine. Ive done stress tests with it for hours on a 3770k with auto OC settings. It gets hot but never above 98C and most gaming it hovers around 60-70C. Id agree it may be the PSU. What about over or undervolting the CPU?
After some thought...I used to have my 3570k @ 4400, but it was unstable while gaming showing similar if not the same issues that you are having. Fix: bumped the OC to 4200, never an issue and hey 200 MHz isn't noticeable.
