Hey guys I have the rose-will Thor V2 (link: http://rosewill.com/products/1798/Pr...l_Overview.htm )
and I am going to outfit it with fans. I was wondering if you guys could help me figure it all out, connectors wise and such.
so for the side panel I am going to put 4 120MM fans (maybe these: http://www.newegg.com/Product/Produc...82E16835553009 )
for the front 230mm Im going to use this (Probably: http://www.newegg.com/Product/Produc...82E16835345036 )
then in the 5.25 cages in the front im using one of these ( http://www.newegg.com/Product/Produc...82E16817996019 )
and replacing the fan (I dont want orange bladed white LED fan in the front og my red and black themed case (http://www.newegg.com/Product/Produc...82E16817996019 )
on the top I am using 2 of these ( http://www.newegg.com/Product/Produc...82E16835146021 )
and on the rear I am using one of these ( http://www.newegg.com/Product/Produc...82E16835181028 )
and I would like to put a fan in the bottom. how much gain would I get from that?
the case come stock with a fan controller. 2 knobs each one having 3 3 pin connectors. no Idea on the wattage.
so how should I wire all of this? I was thinking one of these ( http://www.newegg.com/Product/Produc...82E16811992007 )
how many fans can I use on one channel?
